Reply
NETGEAR R7000 Smart connecting fail from smart phone
Yeshome
Dear all
 I have a problem with smart connect issue.
When i use the cellphone to connect the ap router, then immediately disconnecting from the router.
I try to frequently do that. Finally my cellphone will be connection failed.
What happened with the router? Why i can't connect to ap when i make this experiment.
Thanks!
Yeshome
Model: MC227| Meural Canvas, MC321| Meural Canvas II, MC327| Meural Canvas II
Message 1 of 2
NG_Team
NETGEAR Moderator
Re: NETGEAR R7000 Smart connecting fail from smart phone
Hello YesHome,
It looks like you posted your issue in the Meural forum instead of the Nighthawk forum.  You'll want to post your issue over in the Nighthawk forum, and they should be able to help you.
Meural Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 990 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
