- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
330U firmware needed
- Mark as New
- Bookmark
- Subscribe
- Permalink
I accidently installed the 313U firmware onto my 330U (dumb mistake). Now Windows 7 does not recognize the aircard when it is plugged in. Please help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 330U firmware needed
Have you tried installing the correct version?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I cannot find the 330U firmware anywhere.
This is the firmware I need: SWI9200X_03.00.08.03AP
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello B_s
Have you tried to install the aircard watcher you can find it in the downloads of the support of the 330u page.
http://www.netgear.com/support/product/AirCard_330U_(Rogers).aspx?cid=gwmng
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I was able to install the watcher, but it does not recognize that the stick is installed. The watcher installation does not update the firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
B_S
Do you happen to have any other software from your ISP installed on the PC? If so try to remove it and see if the PC see the the card.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
After much work, I was able to get the computer to recognize that a USB device was inserted. Even so, the watcher never worked. It kept saying there was no device... probably because of the incorrect firmware. I downloaded the AC320U firmware found here:
http://www.netgear.com/support/product/AirCard_320U_(Telstra).aspx?cid=gwmng
I reinstalled the Watcher, and now everything seems to be working.
All that said, I would still like to be using the firmware for my device (330U) not the 320U firmware. Where can I find it?
