× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
AirCard 785S auto shut down
richard_gear
Hi community...
I bought this router because of its ability to start automatically, when power is being provided via USB. This works fine, but when I come back to my car several days later, the battery is always empty. The only options I can see (in the settings via browser and/or Android app) are "Display off" and "Automatic Wi-Fi standby" (translated from German, may be named a little different).  I can set this values (e.g. standby to 5 minutes) and this works fine (the display is off and Wi-Fi is in standby) - but this won't prevent the battery from running empty. Is there a possibility to automatic shut down the card completely after no Wi-Fi connection is used for specific time?
Best regards
Model: AirCard 785S (TELUS)|NETGEAR AirCard 785S Mobile Hotspot
Message 1 of 2
Accepted Solutions
richard_gear
Betreff: AirCard 785S auto shut down
Hi there.
Meanwhile I asked the Netgear support and they said that there is no way to do this with this device.
And with no other device of Netgear (at this time), too.
Regards
Message 2 of 2
All Replies
richard_gear
Hi there.
Regards
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1636 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
