× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
AirCard785S - Speed and connection torubles
MassimoG
Hello,
I bought an AC785S on Amazon and I am having big troubles about speed and connection!
I have a TIM connection at 42,2 speed SIM and I have never had problems about it before: I used the SIM in a Huawei router made custom for this SIM.
Now using the AC785S everytime I connect at first it has no problems apparently but after a couple of minutes the connection becomes slower and slower (on Twitter it starts not loading images, i.e.) and after a couple of minutes later it stops and sometimes my iPad even says there is no connection!
I have tried the SIM inthe old router and it works well it seems not beeing a problem about line.
As I bought the router I updated the firmware and as I put the SIMin the router started to set the values so everything seemed ok but it's not.
What can I do?
I have tried to:
  1. change DNS using the OpenDNS
  2. setting the wifi dual band
  3. restore settings
but no results till now.
What can I do? How can I set the router properly? I thought AirCard was able to set itself automatically...
Thanks for Your kind attention.
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: AirCard785S - Speed and connection torubles
Hello MassimoG
Is the Sim card a Telstra sim card or is it another provider?
DarrenM
Message 2 of 3
MassimoG
Hello!
I live in Italy so there is not Telstra here.
My provider is TIM and I have to refresh the situation: I called TIM and I explained them my problem so they made a "re-boot" (or something like that) for my SIM and now it seems working well!
Thanks!
Massimo
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 4621 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
