- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Aircard 340u Problem with Windows 8.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
I bought a brand new Windows 8.1 Laptop and Aircard 340u. I updated Windows 8.1 fully and then plugged in Aircard in. Supposedly, when you plug it in, Windows is supposed to recognize the device and install the drivers. That did not happen. Nothing happened when I plugged in the device no matter which port I used and no matter how many times I clean booted and tried again.
I plugged the device into a second Windows 8/1 laptop that I have and it worked perfectly - it immediately installed the drivers and worked. I have no explanation as to why it won't work in the new laptop. Neither did AT&T, nor HP, nor Netgear who I spent over 4 hours on the phone with yesterday.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Aircard 340u Problem with Windows 8.1
While a USB hub works, it does add bulk and one more thing to carry around so I would really like to find a way to fix the problem in the USB control. Something happens in the hub that allows the computer to see the modem so surely there is a way to change some USB settings to accomplish the same thing. Maybe a way to downtune a USB3.0 port on the laptop to USB2.0?
Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you ever get this resolved? I have exactly the same situation - New HP Elitebook Folio 1020 with a 340u. It does not work plugged directly in, but works fine if you plug it into a USB 2.0 HUB. It works fine on my old HP laptop without the usb hub.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Jlittle489 ,
Is your Aircard 340u updated to Firmware Version 01.13.12.13 ?
To update firmware on Windows 8, please follow : http://www.downloads.netgear.com/files/aircard/Win8%20Installation%20Instructions.pdf
If you are considering upgrading to Windows 10, here is more information on the device: http://kb.netgear.com/app/answers/detail/a_id/29490
Let us know how it works for you.
NhanN
- Mark as New
- Bookmark
- Subscribe
- Permalink
By plugging the device into another PC and running the AT&T AllAccess Software show that the firmware is "NTG9X15C_01.13.12.13 r18963 ntgrbc-"
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Jlittle489,
Thanks for clarifying. There is a new version 01.13.12.14 now available that was released 8/7/2015.
Please follow the documentation to complete the upgrade.
I hope to hear back from you.
NhanN
- Mark as New
- Bookmark
- Subscribe
- Permalink
I update the firmware again, but still the same issue. It is as if the device is not booting up correctly and reboots itself.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Jlittle
Have you tried updating the drivers for your usb 3.0 ports I checked on Hps website looks like they just released some new usb drivers just a couple days ago. hope to hear your feedback.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Will do! I'll install all the HP updates and report back the USB driver info etc. Thanks for the help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I found no new updates available for my PC. I just found something else interesting. As I mentioned before the device seems to just reboot over and over. I have found that if i plug the device into a "charging only" port of a powered USB hub, it will fully boot up to "Ready to connect".
How much power does this device require from the USB port? It looks as if the laptop is not providing enough power to the device to allow it to startup. I will check my laptop to see if there is some sort of power management that is limiting the power to the usb ports.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Update: I purchased a USB cord that lets you plug into two USB ports at the same time to add additional power (I've seen these on portable hard drives). It is not a hub, just passive usb cable. My modem device works fine with this configuration. The problem is the power being supplied to the USB port is not enough. I tried this on another laptop of the same model (I'm an HP reseller) and it had the same issue out of the box. It is an HP issue.
Thanks for your time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you provide a manufacturer and part number (or link) for that passive sharing cable? I searched around and didn't find it.
I'm having a similar problem with my aircard (it sees power but isn't recognized by the computer and doesn't connect to the network) and was hoping to try this suggestion.
- Mark as New
- Bookmark
- Subscribe
- Permalink
