× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Aircard 781s unite pro att hotspot
Czaka49
Losing connection and bad bandwidth
Message 1 of 3
shellywalrus
Re: Aircard 781s unite pro att hotspot
Same issue - keeps losing connection even with 4/5 bars every 15 minutes or less. Only resolution is restarting, which is annoying. *FRUSTRATED***
Message 2 of 3
Blanca_O
NETGEAR Moderator
Hi @Czaka49 and @shellywalrus
I suggest to check this link for tips and troubleshooting. Or, you can call AT&T for them to check the device.
Blanca
Community Team
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1253 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
