× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Batteries won't charge AC760
askneagain
The modem is just over 12 months old and has trouble accepting a charge. It will work occasionaly but rarely. I have tried other chargers with the same result. Yesterday I managed to get it to 100% today I got it to 50% before it stopped charging. Is it a battery problem or a connection issue?
Model: AirCard 760S (BigPond)|Hotspots
Message 1 of 3
Accepted Solutions
askneagain
Re: Batteries won't charge AC790S
Looks like it is a faulty connection. The battery will charge fine if removed and fitted to a battery charger. The charging leads all work fine with other devices. This could be a fault as this is the second one to do this to me.
Message 3 of 3
All Replies
askneagain
Hi I can remove the battery but how do you charge it independantly, isnt the charger 5v or is it ok to use a 12v source?
Also it is a 790S not a (760)
Model: AirCard 790S (BigPond)|AC790S BigPond Wi-Fi 4G Advanced II
Message 2 of 3
askneagain
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 5845 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
