× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Connect R7000P to MR1100
AML1618
So Frustrating.
R7000P as wireless router to my mobiles,  and computers
R7000P as Wired Router,  through Netgear switched,  to Printer and NAS Storage.
Works 100%,  is Great.
I am connected to the internet through a (Telstra provided) MR1100,  which in and of itself works fine.
How do I connect R7000P to internet through MR1100 ?  I cannot get it to work reliably.
I am using an ethernet cable to join the two devices.
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 2
additude
Virtuoso
Re: Connect R7000P to MR1100
Have you tried taking a verified good ethernet cable from the MR1100 to the WAN port on the Router then go into the router settings/config for the WAN section and set it up as DHCP?
Reboot.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 795 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
