× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Double NAT on xbox
Sawman27
Double NAT on xbox
Trying to play Xbox live and it’s saying I have a double NAT and a strict NAT. I only have the nighthawk hot spot. No router. I just need some guidance! Like Ethernet to the hotspot?? Orrr??? Anything helps!!
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 15
schumaku
Guru
Re: Double NAT on xbox
Not uncommon providers are using NAT, Carrier Grade NAT (CGN), or abusing RFC1918 addresses with CGN for assigning the "pubic" IP address to your mobile/MR1100.
Message 2 of 15
Sawman27
So basically I won’t be able to play video games online?? That’s all I want.
Message 3 of 15
schumaku
Guru
Understood, but nothing the community here can change or enhance on your behalf. Start with challenging your mobile data provider with the keywords from above....
Message 4 of 15
Ksa3344
Apprentice
Make sure these settings are enabled,
settings - Advanced settings - other
UPnP
DLNA
Message 5 of 15
Sawman27
Thank you! I will give it a try when I get home! Any suggestions are awesome.
Message 6 of 15
Sawman27
Still have double NAT and strict NAT. Gonna post some pictures of my setting and see if that helps.!
Message 7 of 15
Sawman27
Message 8 of 15
Sawman27
Message 9 of 15
Sawman27
DNS mode is auto
IP pass through is off
DHCP is checked (use router as DHCP server)
Tethering is off
Message 10 of 15
Ksa3344
Apprentice
Have you tried changing DNS manually to Google DNS ?
Primary : 8.8.8.8
Secondary : 8.8.4.4
Message 11 of 15
Sawman27
I changed it and still double NAT and strict NAT. I have no clue. This is gonna be the death of me...
Message 12 of 15
Ksa3344
Apprentice
What about the LTE band ?
Try to fix each band and see if it works.
i used to have this problem with one specific LTE band with PS4 , when i fixed another band the problem vanished.
so check all the supported bands by your carrier and try them separately.
another thing , move the sim to your phone and tether from it and check if you still have the problem.
Message 13 of 15
Sawman27
Hey man I have no clue what any of that means let alone get to it to check any. I’m going to just have to find somebody here to physically come to my house and see it and try and fix it. I’m sorry. You’ve tried way to hard to be a random person. Thank you very much tho. This sucks.
Message 14 of 15
Eichelberger
When doubling up on devices performing NAT, Xbox One can display the "Double NAT detected" error in the console's network settings. This is often caused by multiple routers of gateways between your Xbox and the internet, preventing it from establishing a steady connection for gaming upsers portal
Message 15 of 15
Top Contributors
Discussion stats
  • 14 replies
  • 4160 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
