- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Dual WAN setup LB2120?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all,
Hope someone can help please.
I have two LB2120 4G modems. They run together feeding into a dual WAN setup on my ASUS router.
Now both connect to the router fine, however I am unsure on the IP settings. I basically want to be able to view both LB2120 modem interface pages right from the ASUS router. However, I can only ever access one of the modems at a time.
LB2120 One = IP: 192.168.5.1. Subnet: 255.255.255.0
LB2120 Two = IP: 192.168.4.1 Subnet: 255.255.255.0
ASUS Router: IP: 192.168.1.1 Subnet: 255.255.255.0 Gateway: 192.168.1.1
If I turn off one of the LB2120, I can always access the other by typing in the modem IP. If both are on at the same time, only one is ever accessable, not both. I thought having changed the IP's so they dont conflict, this would work.
Any ideas or advice please?
Matt
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Dual WAN setup LB2120?
Oh, and forgot to mention. Both LB2120 are running in bridge mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
First, what are you trying to do? Have failover? If that's the case, then you need to look up a protocol called "CARP"
If you're looking to 'gang' them together for more bandwidth, you'll need to look up bonding.
If you've already patiently explained what you needed elsewhere, I'm sorry, I missed it.
