× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Failure of Netgear Technical Support
Capell
I've just bought an LB2120 and I'm having problems with it seeing my FTTP WAN connection from the ONT.
So I went to my service profile and was informed that I had no registered products!!! This is still not working.
Anyway: I registered the LB2120.
Still no registered products!!
So I registered it again.
Now I'm told it's alreadu registered.
I'm beginning to be a little fed-up with this.
Message 1 of 2
Guru
Re: Failure of Netgear Technical Support
@Capell:  You posted your issue in the ReadyNAS forum (which is only for Netgear storage products).  I've moved your post to the correct forum area; hopefully you will get a prompt response here.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 643 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
