- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Frustrated with firmware update for MR1100
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've been using my MR1100 for several years. Lately I've had overheating problems -- frustration #1. I found the "latest" firmware -- 12.07.08.00. That seemed good.
I was surprised I didn't see that earlier so I checked my router's current version. It says 12.05.05. It says "Current software is up to date". Apparently not -- frustration #2.
I looked for the instructions to force an update of the firmware. But my "FIRMWARE UPDATE" page doesn't have an option to upload firmware through the web ui -- frustration #3.
I did notice my web ui has ATT instead of Netgear. Does that shut me out of the update? Is the update even applicable to my MR1100? Is there a separate ATT source for my updates? (And why aren't they automatically detected?)
Thanks,
Joe
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Frustrated with firmware update for MR1100
I have a issue with updating as well. I cannot upfate manually because the borwse to file is not an option, simoply not there. I have a MR-1100-1A1NAS, not purchased through ATT. It just updated the other night, newer fvcirware, but not the current. I solved the over-heat problem by using the router WITHOUT the battery. I have two batteries, and one is unopened, yet, the other I charge it up like once since I got this router. I really like the router so am hoping to find a way to manually update the firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a issue with updating as well. I cannot upfate manually because the browse to file is not an option, simoply not there. I have a MR-1100-1A1NAS, not purchased through ATT. It just updated the other night, newer fvcirware, but not the current. I solved the over-heat problem by using the router WITHOUT the battery. I have two batteries, and one is unopened, yet, the other I charge it up like once since I got this router. I really like the router so am hoping to find a way to manually update the firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply.
The number is MR1100-2A1NAS on the interior of the body. (It would be nice to see that in the "About" screen instead of needing to dissect the router.)
I hope that's the number you want.
Joe
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here is another threaed with instructions. Not sue if I am doing this just yet. If I screw it up, there goes ,my router. I hasd to install jave,s eems it is nmotpart of windows 10. My router did an update a couple nights ago opn its own, but is still not the update to the most current version. https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/MR1100-Firmware-Update/m-p/1813134#M...
good luck, and think this through first. Plenty of times I did updates on my cell with very bad results, hard to reverse that. Been keepping the lastest update from installing on my phone because I DO NOT WANT the vrsion of play protect google is forcing on everyone.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm still looking for some feedback on my MR1100-2A1NAS situation. I see later/newer firmware available. But my router claims it's up-to-date with 12.05.05.
Also, my router has no option to install firmware downloaded from the Netgear site. It only checks for firmware updates.
Am I perpetually stuck with 12.05.05? Or should I be able to get newer firmware?
Thanks,
Joe
