- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Hide Nighthawk M2 model wi-fi username and password
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can’t hide the Netgear Nighthawk Wi-Fi username and password. I also have the M1 model, and to hide those details it’s a simple tick box that stops the details being displayed on the LCD. If I select the same option on the M2 it only masks the username and password with asterixis, but if you click those asterixis on the LCD the username and password is revealed.
Can anyone recommend a solution, please? It’s a real security issue and seems crazy/pointless having the hide function when tapping the LCD reveals the masked details.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Hide Nighthawk M2 model wi-fi username and password
Hi,
Thanks for your reply.
The Model No is MR2100
The SKU reference from the box is MR2100-1EEEUS
Teh Firmware Version is NTGX24_10.13.09.00
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
With FW NTGX24_10.13.09.00, you can disable displaying the detail on LCD by SETTINGS->Setup->Wireless and uncheck "Display info on LCD", then you won't see the detail on LCD. This is done from Web GUI, not on the LCD itself.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I agree the option is there, it was through the Web GUI I unticked “Display info on LCD”, but it does not remove the detail on the LCD, it only masks the username and password (which can be unmasked simply by tapping them) as per my original post.
I have an M1 on the unticking the box works perfectly, but the M2, in my opinion, has a serious security flaw.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, you are right about LCD info which can be retrived easily by tapping the screen, even disable it from Web GUI. This would need to have Netgear to fix it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Recently purchased two of these devices and this security flaw is a MAJOR issue which needs to be addressed immediately.
I have the devices sitting in our office and anyone who can walk up and tap on the screen can access our WiFi.
I might as well print the password and post it in our lunch room for all to see!
I will never purchase a Netgear product for our business!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have 3 of these devices and suffer the same security flaw - is anyone from Netgear able to respond to this thread with an update on this issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear? Is anyone able to respond? It's been months since my last post?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reports and suggestions on this issue.
We will check and see how we should resolve the issue.
Thanks
John
