Reply
How do i manually update the firmware on Nighhawk m1 ( mr1100)?
Sistermoon
Hello and thanks for helping
When i click on "check for updates" in administration manu on router's login page. it says it's uptodate! .  while when i check the version and date and compare it with the netgear site. it shows im 3 years behind.  and on Netgear android app there's also no where to mess around with firmware
I noticed Netgear lets me downlaod the firmware from the site. but there is no way for me to upload it into the device..
are there anyway i can do this?
Thank you very much and excuse me if this has been asked B4
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 9
Sistermoon
Re: How do i manually update the firmware on Nighhawk m1 ( mr1100)?
To add more details. Its AT&T  unlocked.  with no option to manually upload the firmware
Edit:  To add more details... It's not unlocked anymore.. I har reset it and it's back to locked ! -__-
Message 2 of 9
antinode
Guru
   "there is no way"?  Interesting conclusion.  Any basis?
   Visit http://netgear.com/support , put in your model number, and look
for Downloads.  (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".)  Find the kit(s).
Download the kit(s) you want.  Read the "Release Notes" file for
instructions.
Message 3 of 9
Sistermoon
Hi and thankd for your reply...
by not being able to upload teh firmware manually i mean theres no field for me to upload the firmware into device. i will take screenshots if it helps...
Screenshot from 2021-07-25 15-53-51.pngScreenshot from 2021-07-25 15-55-57.pngThank you for your time
Message 4 of 9
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so there may be useful responses here, but mobile routers and hotspots differ from standard routers in many ways, so you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 5 of 9
Sistermoon
Thanks for moving my thread to correct section. ALso if anyway know of a way how to TFTP into MR1100 it would help me and mny others.
Message 6 of 9
You are welcome. Did you try this?
Search - NETGEAR Communities – mr1100 update firmware
Just another user.
Message 7 of 9
Sistermoon
Ofcourse. First thing i did.  only one topic has same question and at the end he asks if anyone tried to TFTP and no one answered.
Message 8 of 9
Feeldennis
Tutor
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 681 views
  • 4 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
