× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
How to Unlock a Sierra Wireless Aircard U330?
maximumeffort
Follower
Hello,
I'm already familiar with the Aircard Watcher Software to help unlock
I have already obtained 3 codes for 3 Aircards that I need unlocked
Unfortunately, after the process I still get the error message "Incorrect Sim" (I'm using a USIM that is not from my provider in order to unlock)
The agent on the phone suggested to add four 0's in front of my 12 digit unlock code. Now I am wondering, for a cellphone its either 16 digits or 8 digits for an unlock code. Is it normal that my U330 codes are 12 digits long?
thank you
Model: AirCard 330U (Bell)|4G LTE Sierra Wireless U330 Turbo Stick (AirCard 330U)
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: How to Unlock a Sierra Wireless Aircard U330?
Hello maximumeffort
The code should be 8 digits and you will have to contact the ISP again to get the correct code
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2747 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
