× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Is mr1100 a firmware upgrade possible?
leesteve
Tutor
I am currently using AT & T version but it is not available because it is used in other countries
There is no webpage window to select an upgrade file so nothing is possible. Is there any other way?
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 10
Accepted Solutions
FCB90
Star
Re: Is mr1100 a firmware upgrade possible?
Yes, it's possible.
Download the file (newest FW for ATT):
"MR1100-100NAS_23113828_NTG9x50C_12.05.05.00_00_GenericNA_01.02.secc"
and upload it using "fdt.exe".
More informations can be found on WWW.
Message 2 of 10
All Replies
FCB90
Star
Yes, it's possible.
Message 2 of 10
leesteve
Tutor
No I need NTG9X50C_12.05.05.00_ATT_03.12 firmware instead of NTG9x50C_12.05.05.00_00_GenericNA_01.02.secc version of the firmware
Because I am using the MR1100 ATT model
Message 3 of 10
FCB90
Star
Generic software works perfectly on ATT 1A1NAS and 2A1NAS devices.
Just install it, come back and thank me.
Message 4 of 10
leesteve
Tutor
Is this the FDT program you mentioned in the Flash Development Toolkit (Renesas)?
If you do not mind, can you tell me more?
Message 5 of 10
FCB90
Star
PM.
Message 6 of 10
Rambo974
Hi,
I have the same problem, I have a M1 AT & T that I would like to update.
did the update via Flash Development Toolkit work?
Message 7 of 10
Rambo974
Hi,
Do you have a solution to apply the original Netgear WebUI interface to an AT&T model?
Message 8 of 10
nomad247
Tutor
Hello, I have a similar issue and it was recommended I too upgrade the firmware. The message you posted said more info at www but there is nothing else after the www. I googled the info, found a site but have idea how to upload using the FTD unto my router, which works every well with one except. After charging it, and unplugging the charger, within an hour, it shuts down and I cannot power it up unless I remove tha battery and put it back in. I really like this router, too bad Verizon does not have one.
Message 9 of 10
Rambo974
@nomad247 : do you plug-in an microSD card ? I have an "over heating" issue when I have an microSD card inside the M1. I suggest you to take it off (USB key too) and see if this solved the problem you have.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 4981 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
