× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Is there any limitations on running MR1100 without battery?
Retired_Member
Not applicable
I plan to connect the hotspot to a home router. Will I be able to update the hotspot if there is no battery connected to the hotspot? Thanks
Message 1 of 3
Retired_Member
Not applicable
Re: Is there any limitations on running MR1100 without battery?
I am going to purchase the device without battery and the reason for that is because the exporting country customs will not allow it to be shipped with its lithium battery inside the box.
Message 2 of 3
JohnPeng
NETGEAR Expert
Without battery, you are not allowed to upgrade the device. This is a feature to protec the device from being bricked due to sudden loss of power if no battery inserted during upgrade.
We are going to sell satndalone battery for M1. Please check. Maybe you can buy the battery later.
Thanks
Model: MR1100|Nighthawk M1 Mobile Router
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1181 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
