BrenC11
Sep 24, 2021Follower
Issues with Nighthawk M5 - Disconnecting 4G every few days
HI Folks
I use my MR5200 for 4G and 5G internet connected to a Tp_link AX1800 Wi-Fi 6 Router. I followed this guild to set it up.
https://www.youtube.com/watch?v=9t1RJsYymGg&t=68s
It seemd to work, the speed was much better and my smart home devises work seamlessly with the TP-link (was always having isseus with the M5), but for some reason the M5 disconnects from the 4G/5G singnal every 24-48 hours and I need to reset it. When this happens I also cannot use the app to connnect to the M5.
I have turned the Wi-fi off on the M5 and its connected straigh to the internet port on the router.
I know the cause of the issue could be many things, i just need to start a process of elimination to fix it totoally.
I have my internet set to dynamic IP.
The TP-link is set to 192.168.0.1
Is there a log on the M5 that I can acesss, cant seem to see anything on the app.
Any help would be much appreciated.
Thanks
B
1 Reply
Please visit and post about this over in the Mobile Routers forum:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
Thank you.
