- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
LB1120 Remote Access
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an LB1120 in our RV that is connected to a router and web server. I would like to access the the LB1120 via an HTTP call to retrieve the current status of the connection. I'm assuming that I could send a request with login credentials and parse through the Dashboard page. Are there any web services or other means to get the status of the connection ? Connection status and signal strength.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: LB1120 Remote Access
Unless your LB1120 does run in router/NAT mode, it won't have a public IP address assigned - as you connect it to a router, it's the router WAN/Internet interface getting the address. Permitting your mobile ISP does assign a public routeable IPv4 address (and not deploy carrier grade NAT), you can reach your router or a system on your LAN and have to check the LB1120 status from there.
