- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
LB1120
- Mark as New
- Bookmark
- Subscribe
- Permalink
LB1120
Few questions about external antenna.
I want to replace my at&t beam 340u which I have an external antenna being used that gives me decent 4G LTE speed. I an using only one external antenna connection on the at&t beam 340u. I see the manual says the LB1120 needs to connect both antenna ports. Can I use only one port on the LB1120 or do I need two. I read where to get MIMO you need to use both ports. I am a little confused. Do I need another antenna or need to buy a MIMO antenna?
Thanks for the help.
Don
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: LB1120
im using a MIMO antenna but have noticed that when plugging only 1 atenna lead in the signal jumps up. so i would say yes you can use just 1 lead but to get the MIMO function you will need 2 antenna's or a MIMO antenna.
