× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
LB2120 Feature request - ping test fail over setting
ryannelson
Tutor
Hello,
The LB2120 is a great device.  It is able to do almost everything I want.  However I wish I had a setting where I could configure how often the ping test for detecting failing over happens.  Meaning the time interval for when the ping test happens and either fails or successeds to determine if the device should fail over from the landline connection to the celluar connection.
Is this feature available and I'm not aware of where it is?
If its not available can the be added to a firemware update.
Thank you,
Ryan
Model: LB2120|4G LTE Modem
Message 1 of 3
Blanca_O
NETGEAR Moderator
Re: LB2120 Feature request - ping test fail over setting
Hi @ryannelson
Welcome to NETGEAR Community!
We recommend posting your suggestion on our Idea Exchange board. Our Product Managers review the board for great ideas to be implemented in future releases. Link is https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Blanca
Community Team
Message 2 of 3
ryannelson
Tutor
Done.
Thank you,
Ryan
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 917 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
