× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
LB2120 How to SMS a command eg #11#
BarryTreg
Apprentice
Is there a way to sent an SMS using a special code ? My SIM provider asks for an SMS to be sent to #11# to get a reply back on the amount of data left on the plan. When I try and enter #11# the LB2120 says it's an invalid number.
Don't really want to take SIM out and put it in a phone to check data usage.
I have a 365 day prepaid SIM that I use as a backup so the monthly measurements in the device aren't much use.
Thanks
Model: LB2120|4G LTE Modem
Message 1 of 3
RVALENZ
NETGEAR Moderator
Re: LB2120 How to SMS a command eg #11#
Hi Barry,
Good day!
Welcome to NETGEAR Community!
First of all, we do apologize for the inconvenience of not getting back to you immediately due to the back log in the system.
Please do not hesitate to let me know if you need further assistance.
Unfortunately, you need to check it via phone since the device cannot send a text message.
Rhys
Community Team
Message 2 of 3
LlamaLarry
Luminary
What does the Messaging selection on the left side do then?  If you select Messaging it says (for me) "No SMS Messages" and has an open to create a New SMS message...
Does this just not work but Netgear left it in there to enhance confusion?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1423 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
