× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
LB2120 LTE Plantage
srekik
LB2120 LTE Plantage
Bonjour
J'ai constaté un plantage régulier de la box : presque tous les jours.
Il faut la débrancher et rebrancher au secteur pour la redémarrer.
Quand elle plante :
  • Led Power : allumé en rouge fixe
  • Led Lan : allumé en vert fixe
  • Led Barres de Réception :
    • S1 et S2 : allumées en vert fixes
    • les autres éteints
Cette situation n'est pas décrite dans la documentation en cas de dysfonctioonement.
LA box envoie très peu de donner : un petit mail par jour.
Bien Cordialement
Model: MR1100|Nighthawk LTE Mobile Hotspot Router (US)
Message 1 of 5
JasonN
NETGEAR Employee Retired
Re: LB2120 LTE Plantage
Hi srekik,
Is your device up to the most current firmware? Have you done a factory reset on it?
Your LEDs for the LAN and Signal Strength seems normal except your Power LED. The LED for your power should only be between the colors of Green & Amber.
Can you confirm if it is red or amber? Thank you :]
- Jason N
Message 2 of 5
JasonN
Hi srekik,
I just wanted to check up on you and see if you're still having the issue. Please let me know :]
- Jason N
Message 3 of 5
srekik
Hi Jason
I haven't take care if its is solid RED or solid Amber. But it seems
rather Amber see photo below.
In fact the router is connected to a PC on LAN1. The PC sends once per a
day a short sms about the state of connected devices to local LAN.
The router is installed in a remote site far from my office.
No antenna was connected to the router.
For the moment I replaced the router by a D-LINK DWR921 with integrated 4G antennas.
I have succeeded now in my office to update firmware but remote update trials. have failed.
I will make new tests as soon as possible.
Mean while I added the ability to send a new empty sms every hour as a
keep alive signal to better control the router working status.
For the moment I have no problem with DWR921.
Best Regards
+33 6 27 76 73 36
Samir REKIK
Aris Technologies
Message 4 of 5
JasonN
Hi srekik,
Thank you for your response! Please update me when you have found out. :]
- Jason N
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1166 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
