× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
LB2120 not connecting to BT Fibre Modem
rolyretro
Follower
Hi
I have just bought an LB2120 to act as a failover device for my fibre broadband, which is currently cutting out, with no sign of resolution from BT.
I have a 4G card from three, and this connects fine when I turn on the LB2120.  I get 4 bars, and was able to download a firmware upgrade via the 4G connection.
When I connect it to the BT Openreach cable modem however, I get "Wireline Unavailable".  Whatever combination of router or bridge settings I use, I cannot get a wired connection to the internet.
Is there a special setting I need for the BT cable modem, or is my LB2120 faulty?
Thanks
Alex
Model: LB2120|4G LTE Modem
Message 1 of 2
JohnPeng
NETGEAR Expert
Re: LB2120 not connecting to BT Fibre Modem
Maybe you have tried the settings below. That is what I can think of now.
1. Connect LB2120 WAN port to your BT cable modem LAN port
2. Make sure LB2120 and BT cable modem are not set in the same subnet. The default IP gate for LB is 192.168.5.1. Please check your BT box use 192.168.xxx.1, which xxx is not 5.
3. Enable LB failove feature and set BT modem as default connection.
Thanks
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 924 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
