- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
LM1200 repeatedly dropping link
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: LM1200 repeatedly dropping link
- Mark as New
- Bookmark
- Subscribe
- Permalink
I gave up. They were trying to schedule a call with me and got to busy to call at the scheduled time. I cant spend any more time on this. I am returning the LM1200.
I did have a LB2120 at work and borrwed it to see if it would work any better. I am not seeing the link drop outs like the LM1200. I do have issues sometimes getting an IP in bridge mode, but it seems better.
This is so frustrating because I have wasted HOURS AND HOURS on this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry I never contacted Verizon. I am still going to ask them about this, but I am giving up on Netgear and the LM1200 because of so much wasted time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I found this thread because I bought a LM1200 back in July, also on Verizon, also using pfSense, and discovered I'm experiencing the exact same issue. When I have the LM1200 plugged into a laptop, it works, no problem. As soon as pfSense starts sending traffic to it, the LTE light flashes red, and the device goes in an endless cycle of connecting and reconnecting. I contacted Netgear for a warranty replacement but that went nowhere. This point, I'm out of my return window and I'm frustrated with this thing. It's not even like I can use it in the car since there's no wifi on it. I'm on the latest firmware and that didn't do a thing other than enable the WAN port which I don't use.
Edit: So I did try putting the LM1200 into router mode. This kept it from dropping the LAN connection, but the Verizon side just kept rotating through IPs. Now, the LTE light is a steady red and I have an alert that mobile broadband is disconnected. I'm probably going to have to call Verizon now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for reportng the issue. Could you please help to capture some logs on the disconnection issue? I can provide instructions if you can.
John
- Mark as New
- Bookmark
- Subscribe
- Permalink
How would you like logs? Wireshark or are there logs I can get directly from the LM1200?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am happy to provide logs as well. Just let us know what you are looking for.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your help in advance. I sent the logging instructions to you in private message.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@JinTu Thank you for capturing the logs. The initial anaylsis points to the issue to handle Verzion SIM activation and APN dynamic change. The issue seeem only limited to using Verizon network. We are still investigating. I will ask your help again when we have a potential fix on the issue.
In our own testing using other carrier network, we couldn't reproduce the issue.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having the exact same issue and working through it now with support... my modem will randomly go through instances of the network connection repeatedly cycling (every 30s or so). I'm on verizon. The disconnect for each cycle seems to follow a instantaneous status change to the cell signal light, which may sometimes flash red a single time at the start of each cycle. When this was connected to a router with more detailed logging, the WAN gateway would flip / flop with each cycle. I have ruled out issues like the specific PC / router connected to the device, network cables, physical location of modem (different cities), etc. The problem is likely either 1) the unit is switching between cell sources, such as 3G vs LTE, and it's causing the modem to reset the network adapter or 2) the service provider verizon is sometimes switching between IPV4 and IPV6 and the modem / downstream devices aren't digesting it well.
It could also be a combination of the two factors above. I'm not savvy enough to force these external states upon the modem to narrow it down further, but I've mostly ruled out everything under my control on the device / network side.
If I'm able to catch another wave of resets with everything ready to go, I'm going to try to switch the Network Mode from Auto to LTE (to elimate its ability to switch between LTE and 3G) and also try setting the default PDP from IPV4V6 to just IPV4.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is happening to me as well.
Dual NETGEAR 1200s > TP-Link Omada > TP-Link Archer A10.
The Details:
Firmware Version: EC25AFFDR07A09M4G
App Version: NTG9X07C_20.06.09.00 Web
App Version: LM1200-HDATA_03.03.103.201
Hardware Version: 1.0
View from the Omada attached.
Peaks correspond to LINK DOWN, valleys to +/- 30 from LINK UP
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Details:
Could you please confirm which carrier's SIM you are using, Verizon?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am also having the same exact issue, works fine plugged into a laptop. As soon as i plug into my sonicwall or other routing devices it drops out. updated firmware, reset to default. Doesnt work in bridged or router mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did just find if i plug the LM1200 into a TP link Archer 750 it works just fine. I can then plug my Sonicwall into it and it works through the lan fine. So there seems to be something going on with some kind of port security or buggy kind of issue on the port on the lm1200??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Could you please detail how you connect the 2 different routers? Just connect them to LM1200 LAN port and one is working and one is not working?
Please provide Sonicwall's model.
- Mark as New
- Bookmark
- Subscribe
- Permalink
We are investigating the issue right now that when using Verizon SIM card, sometimes, the data connection keeps dropping . Will get back to you soon after we find the root cause.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think there are 2 different issues reported in this thread.
1. LTE connection keeps dropping when Verizon SIM is used. This is being investigated. IT may be related to Verizon plan used.
2. LAN connection dropped when connecting LM1200 LAN port to a WiFi router.
Please check the issue you have and specify clearly whether it is LTE connection drop or LAN connection drop.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm using two LM1200s, each with a different carrier SIM, load balanced using an Omada.
The two SIMs currently in use are a TMO SIM and a VZN SIM.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the details. After we found the solution for the Verizon LTE drop connection drop issue, I would like to ask your help to verify the fix.
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am using a SonicWALL TZ370. I am connecting dircetly to the WAN port with a CAT6 patch cable. When it is plugged in directly to my pc, or the TP-Link Archer 750 is works as it should. When plugged into the Sonicwall TZ370 the following is what happens.
1. The device pulls a DHCP address from the Netgear LM1200
2. I can ping out to the internet 8.8.8.8, google.com for about 6-8 packets and then the connection drops
3. The ethernet connections light goes off and pings begin to fail
4. After a period of time the connection light comes back on and pings resume for 6-8 packets, then it drops again.
5. I also notice the Sonicwall pulls another DHCP address from Verizon each time the connection cycles.
I'm not sure if this is a LTE problem or a Netgear problem, but either way its not working like it should.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please confirm the following are the correct summaries of your issue.
1. You are using Verzion SIM
2. The connection LM1200 LAN Port -> PC Ethernet: This is working fine
3. The connection LM1200 LAN port -> TP-Link Archer 750 WAN port: This is working fine
4. The connection LM1200 LAN port -> Sonicwall TZ370 WAN port: The connection will keep dropping
Thanks
