× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
LM1200 with AT&T phone plan instead of hotspot
I get a much better rate adding an additional phone to my AT&T plan. I have a phone that I can tether, if I loose my cable modem.
Does anyone know if I can use the sim from my phone in a Lm1200 without changing the plan?
Message 1 of 2
JohnPeng
NETGEAR Expert
Re: LM1200 with AT&T phone plan instead of hotspot
LM1200 is certified with AT&T. So the AT&T BYOD hotspot plan will work for sure. If your phone plan was from a promotion, most likely, AT&T will blokc the data service to be used with other devices. But you can give it a try.
Thanks
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 804 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
