× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
LTE Antenna
Griffo56
Follower
LTE Antenna
I currently have a poor LTE signal from my carrier. Will connecting an antenna improve this? If so where can I get them in Australia. Thanks in advance
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 2
W1lliam
Virtuoso
Re: LTE Antenna
External antenna might improve your signal quality, depends if your problem is more on signal strength or stayed on poor band where available bandwidth is not expected.
Check on LTE MIMO antenna from your local store, or online seller, for LTE antenna with TS-9 connector, don't get too long antenna cable (1 meter should be sufficient for home) as cable length would induce more loss.
Try to lock on a band (Google "LTE band lock M1") that gives you better bandwidth in your area, this can be done without spending money and see if it does improve.
William
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 816 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
