- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Lb1120 power light solid amber and lan light solid green
- Mark as New
- Bookmark
- Subscribe
- Permalink
This happened randomly an hour or so ago. Everything was working fine and then the power light stayed solid amber and the lan light appears afterwards, flicks a bit, then stays solid green. The five bars in the middle do not light up. I resetted, disconnected and reconnected the modem to no avail. I believe there's internet access, but do not know what to do to fix this issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Lb1120 power light solid amber and lan light solid green
Hi @MrBunster
Welcome to NETGEAR Community!
Kindly check link below for the list of error conditions indicated by the Signal Strength LED bars and possible solution:
https://www.downloads.netgear.com/files/GDC/LB1120/LB112x_UM_EN.pdf [page 85 - 86]
Blanca
Community Team
