× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Limit/block devices when LB2120 LTE model is in failover mode
m8473
Using an LB2120 as backup to cable internet service at a rental unit. It sits between the cable modem and our Netgear R6700 Nighthawk wifi router.
When the cable internet fails it is important to keep connection with the security cameras, door locks, thermostat, and weather station. But I don't want to be paying LTE data rates for other connected devices (renter devices on the guest network, TV streaming video, etc.). Is there a way to block all devices except those we need to keep active when the LB2120 is in failover (LTE) mode? It needs to be automatic - not some manual reconfiguration of the LB2120 or the Nighthawk router. Is it possible?
Thanks.
Message 1 of 2
wombat71
Re: Limit/block devices when LB2120 LTE model is in failover mode
According to the manual, you can filter, but as I don't see it on my LB2120, I'm guessing either:
1) feature was removed in the version of the firmware I'm running
or more likely
2) not available in bridge mode
As you have to be in bridge mode for the failover, perhaps what you're doing isn't possible?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1489 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
