× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
MR1100 APN settings from AT&T to Verizon
Innovative
Follower
This was posted some time ago, looking for a resolution.
Changing AT&T APN on Netgear Nightawk M1 MR1100
Hi all -- Thanks for the terrific advice on getting my AT&T Nighthawk MR1100 unlocked. The unlock code all processed, and it recognizes the sim and network from other providers. However, I can't change the AT&T APN to those required by the other providers. I've tried all sorts of proposals from this site and elsewhere on the web. For example, I've tried editing it using the app or browser, I've tried deleting it and adding a new one, etc. I can add another APN, but it always goes to AT&T as the default. And the AT&T APN can't be edited or deleted in either the app or browser. And yet, it recognizes non-AT&T sims and networks. It just don't fully connect to the network without the appropriate APN.  Very frustrating. Any suggestions? Thanks so much.
APN Name: Verizon
APN:  vzwinternet
PDP: IPV4
all others blank
Message 1 of 2
Blanca_O
NETGEAR Moderator
Re: MR1100 APN settings from AT&T to Verizon
Hi @Innovative
Welcome to NETGEAR Community!
You may want to check this community link and see if it resolved the issue:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/Nighthawk-MR1100-At-amp-T-Unlock-hel...
Blanca
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 8335 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
