× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
MR1100 Firmware Update
FilB
Hello
I've tried to download the new firmware as provided from Netgears Support page for the MR1100 router.
My current firmware version is 12.04.02.00 and according to the Netgear website, version 12.05.05.00 is now available.
After downloading the file and installing it via the updater within the router it tells me this update is not for my device?
Any ideas why it wont update?
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 2
schumaku
Guru
Re: MR1100 Firmware Update
Where ever you have seen that, whatever firmware you have downloaded, whatever MR1100 you have - zero information.
Check your MR1100 exact product designation on the label (inside, under the battery)...there exist many different variants customized for various providers:
The better area for your product would be the Mobile Routers, Hotspots & Modems community section, convinced a moderator will move this thread.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1832 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
