× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
MR1100 Nighthawk M1 -- Stuck on Firmware Update
glpglp
The unit is stuck on "NETGEAR" start up screen and will not turn on. It gets power and the screen lights up with "NETGEAR" but nothing happens except a steady on Orange/Red light.
Took out the battery and plugged in the USB-C port to power and held down the Power button for 5 seconds while it was booting up and the screen changed and shows "Downloading software update".
So I would assume that a software update got stuck and the unit is non-functional. Also, I have tried doing the Reset button many times with many sequences and this has not helped either.
QUESTION: Is there a way to restart the unit or do a manual firmware installation?
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 9
JohnPeng
NETGEAR Expert
Re: MR1100 Nighthawk M1 -- Stuck on Firmware Update
Please let me know the SKU name of the device (MR1100-xxxxxx). It is printed on the product label.
How long have you bought the device?
Thanks
Message 2 of 9
glpglp
Any thoughts on how to fix this?
Model: MR1100
SKU:  6420B
Purchased approx:  06/2019
Message 3 of 9
JohnPeng
NETGEAR Expert
This is AT&T SKU. Please contact AT&T to get a replacement if possible. The device has to be repaired.
Sorry for the inconvenience.
Thanks
Message 4 of 9
Gbarr119
Same device, same question. ATT says contact Netgear, out of their warranty.
Message 5 of 9
AnitaSilva
Message 6 of 9
Gbarr119
I can boot the device to, Downloading software screen, by holding the power button, w battery removed, and plugging in the power cord. Just don't know how to get the firmware into the device.
Message 7 of 9
SBMcaden
Is there a solution to this? I have the same problem and cannot find a solution
Message 8 of 9
mygroudnbiz
Thanks for sharing nice information.  Mygroundbiz
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 4633 views
  • 0 kudos
  • 6 in conversation
Announcements
Orbi WiFi 7
