× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
MR5100 5g hotspot 2.4 ghz wifi slow slow
jestexman
Tutor
Just recived one of these..   the ethernet is getting around 50 down and 15 up.. 5 ghz is getting about 50 down and 15 up.. 2.4 is getting 10 down and 2 up..
What i am i missing.. This thing is getting double the speed of my Samsung S20+ so that is great.. I am assuming it has to do with the CA.. I would sure hate to have to buy another router to plug into this just to get them speeds.. but it seems that is what i might have to do.
Firmware is up to date.. Running on Att Firstnet..
Message 1 of 2
JohnPeng
NETGEAR Expert
Re: MR5100 5g hotspot 2.4 ghz wifi slow slow
Can you manually set 2.4Ghz WiFI's channel to avoid interferences from other WiFi clients? It may help you to improve the 2.4Ghz WiFi TP.
Thanks
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1157 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
