× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
MR6500 Pro Power Issues
MCW_304
Follower
MR6500-1A1NAS
Firmware: NTGX65_10.01.31.01
Purchased from ATT.
Troubleshooting steps so far:
  • AC adapter without battery - Device powers on but will not stay on. Removing the type-c from the device and back in makes it power back on, but will not stay on.
  • Device will not power on at all when battery is inserted.
  • If battery is inserted after device is Ac powered on, device turns off.
  • Tried a 2.4A charger (as suggested for other models) but that does not work - image on screen makes it seem like i'm trying to use it with a laptop rather than a charging adapter.
  • Factory reset button does not fix problem.
  • All sleep/power settings have been checked.
  • It seems that if I babysit it - constantly hitting the power button to wake it up - then it will stay on. But if I just leave it idle, it shuts off.
ATT tech support did not try to troubleshoot - only processed a replacement but the unit is currently out of stock. I thought maybe someone here may have some suggestions.
Thanks!
Message 1 of 2
Blanca_O
NETGEAR Moderator
Re: MR6500 Pro Power Issues
Hi @MCW_304
Are you still experiencing this?
Were you able to get replacement from AT&T?
Blanca
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1444 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
