Reply
Highlighted
MYSIMPLELINK
I have an unknown device showing in my Genie that is called MYSIMPLELINK and I would like to know if I should block it and if so, HOW? I have tried to block it, but it is still showing up.
Message 1 of 7
Accepted Solutions
Highlighted
Guru
Re: MYSIMPLELINK
I have a feeling its part of the ring doorbell.
https://community.blinkforhome.com/t/what-is-mysimplelink/8313
Ring and blink are both owned by amazon.
CM2000-> Arris AX11000 W31-> GS716v2-> WAX***-AP
Message 6 of 7
All Replies
Highlighted
Guru
Re: MYSIMPLELINK
do you have any wifi camera's, video doorbells, etc?
MYSIMPLELINK tends to be wifi cameras or doorbells.
Message 2 of 7
Highlighted
Re: MYSIMPLELINK
Yes, but it shows on the device list as well.
Message 3 of 7
Highlighted
Guru
Re: MYSIMPLELINK
More than 1 camera or a sync module like blink has?
Message 4 of 7
Highlighted
Re: MYSIMPLELINK
I only have a Ring doorbell.
Message 5 of 7
Highlighted
Guru
Re: MYSIMPLELINK
Message 6 of 7
Highlighted
Re: MYSIMPLELINK
okay, thanks!  I will  check out that link.
Message 7 of 7
Discussion stats
  • 6 replies
  • 5824 views
  • 0 kudos
  • 2 in conversation
Announcements
