× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Mobile broad
Viro_Major
Follower
Mobile broad
Hi all, new here
I have a few questions regarding the MR2100 unit
https://www.netgear.co.uk/home/products/mobile-broadband/mobilerouters/
Can it be plugged to a router and act like a 5G backup over a ethernet connection ?
Can it be plugged on the wall with an AC adapter or only works on batteries ?
Thx
Message 1 of 2
Blanca_O
NETGEAR Moderator
Re: Mobile broad
Hi @Viro_Major
Welcome to NETGEAR Community!
If you plan to run the device 24/7, we suggest you to power the device with the PA only without inserting battery. This way, it will avoid the battery from getting hot and impacting the device's performance.
MR2100 does not have failover support.
https://www.netgear.co.uk/home/products/mobile-broadband/mobilerouters/M2.aspx
Blanca
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 633 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
