× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
My android phone doesn't automatically reconnect if it goes out of range
Jamie1234
Follower
This is a real pain... everytime I take my phone away from the house and come back again, I have to tap the screen on the modem to reconnect the phone.  Can't it automatically connect once it is in range again?  Thanks for your advice in advance.
Model: MR2100|Mobiler Router Nighthawk M2
Message 1 of 2
Blanca_O
NETGEAR Moderator
Re: My android phone doesn't automatically reconnect if it goes out of range
Hi @Jamie1234
Welcome to NETGEAR Community!
If there is no activity for a period of time, the device will power down to save battery power. Pressing the power button will wake it up. You can change the WiFi standby time by doing the following:
Access UI > Settings > Setup > Wireless > change WiFi Standby to Disabled.
Blanca
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 980 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
