BohemieAnnie
Feb 28, 2020Follower
NETGEAR LB2120
Hi, I have an LED issue. The unit was purchased new in Oct of 2019. The first (power) and fifth bars are lit up but nothing on the 2,3 and 4th.
I’ve checked thru the manual in troubleshooting and this kind of configuration isn’t shown.
It was working fine and this happened. I’ve re-set everything and checked thru forums, but don’t see anything like my issue.
Any ideas? Suggestions?
Thanks so much:
Thanks so much:
1 Reply
If all the signal lights are off it could mean:
1. you don't have service there
2. bad sim card
3. cell service has been shut down from cellular provider
4. The device is bad
5. APN isn't set right for your provider.
Have you checked with your cellular provider to see if your account is fine?
Have you had your sim card checked out?
