× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Need MR1100 Nighhawk Mobile Hotspot APN Settings for ATT
87MikeR
Initiate
In working with ATT on another issue they had me change all the APN settings in my MR1100.  Unfortunately no one at ATT seems to know what these settings need to be.  I need the correct ATT settings for:
APN Name:
APN:
Authentication:
PDP Type:
PDP Roaming:
Right now I have these set to the following:
APN Name:  ATT
APN:  Broadband
Authentication:  None
PDP Type:  IPv4
PDP Roaming:  IPv4
It will connect and work with ATT, but it is very slow (2Mbps on average in a speedtest).  I found the APN settings I entered on the web and was not very confident they were really optomized so wanted to see what others were using.  Thanks.
Message 1 of 2
Accepted Solutions
Guru
Re: Need MR1100 Nighhawk Mobile Hotspot APN Settings for ATT
Might have better luck in the mobile hotspot forum and not general router forum.
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
Message 2 of 2
All Replies
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3657 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
