× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Netgear M1 not connected to the router.
786Puru
Follower
Hi Folks!
I hope everyone is doing well. The reason for writing is I was trying to setup my visible sim to netgear M1 router. But, It’s saying no devices found or insert sim card . Even though the sim is inside.
However, I read all the threads relating to setup router with new visible sim. Even after applying APN instructions from you folks. It’s still saying not connected. So, what would you folks have suggestions for me to setup the M1 router with Visible sim. Please guide me in this. Hope to hear positive response from you folks. Thank you
SKU: 6420B
MAC: 100C6B7CDD97
Model: MR1100
Message 1 of 2
W1lliam
Virtuoso
Re: Netgear M1 not connected to the router.
6420B basically is a locked model, you would need to check whether or not this device is unlocked or you are using a SIM card that is allowed to have hotspot installed. APN needs to be set for that particular SIM card, different from one carrier to another if your device is unlocked.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 508 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
