× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Netgear MR1100 Mobile broadband disconnected
wilburleesmith3
Initiate
My nighthawk m1 worked fine Friday night and I woke up to the screen saying mobile broadband disconnected. My phone (both at&t service) has 3 bars. Every once in a while it will show Default net work then Go back to the previous message. Went to settings and data is on and everything set at factory settings. I’ve factory reset it the router and changed SIM cards to no avail. Someone please help!!!
Message 1 of 3
Accepted Solutions
wilburleesmith3
Initiate
Re: Netgear MR1100 Mobile broadband disconnected
I had to get a new sim then go into settings and select LTE ALL under network settings
Model: MR1100|Nighthawk M1 Mobile Router
Message 3 of 3
All Replies
Reco6901
Did you get this issue fixed? I’m having the same problem!! On two NETGEAR MR1100 hotspots both AT&T simcards !
Message 2 of 3
wilburleesmith3
Initiate
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 48430 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
