× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Netgear NightHawk MR1100 no longer shows data usage after firmware update.
mbwallace
Follower
I have a Nighthawk M1 mobile router model MR1100 that I use with AT&T cellular. The device has worked flawlessly for years now. However, earlier this month it automatically did a firmware update - after which the device no longer shows my monthly data allotment and how much data I have remaining. I have seen some post that others have had similar issues with this product with other carriers but without an evident resolution. Not sure whether a factory reset worked for them or a return to the previous firmware.
My device information is as follows:
Hardware Version: 1.0
Pri Version: 05.08
Firmware Version: NTG9X50C_12.06.21.00
Bootloader Version: NTG9X50C_12.06.21.00
GUI Version: MR1100-1A1NAS_04.01.70.13
Firmware Build Date: 2021/01/08
I have tried a factory reset without possitive results. I would attempt uploading the previous firmware, but on the firmware page it just says that the firmware is up-to-date and there is no button or option to upload a file. I don't know if this is because I am only attached over. I did try putting the unit on charge just in case being on batter was a limitation.
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 752 views
  • 1 kudo
  • 1 in conversation
Announcements
Orbi WiFi 7
