- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear Nighthawk M2 Firmware Download
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear Nighthawk M2 Firmware Download
not sure why, but when I clicked check firmware upgrade, it works when I was with carrier for non-Australian
- Mark as New
- Bookmark
- Subscribe
- Permalink
@W1lliam Ohh ok so I get it now, whatever carrier you are on now with, its that carriers settings your getting from their Firmware which are different to Telstra here in Aus. So therefore you get the I.P. passthrough. The carrier your with must be selling the M2 also then, but you just have the Aus version. It must be unlocked too is it to work on that carrier?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. The information is helpful.
Regards
@KrzysztofKarol wrote:
If that helps:
Country: Switzerland
Firmware Check
does not work with digitec (Sunrise)
works with Salt
Firmware Version: NTGX24_10.17.01.00
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Gerald,
IP passthrough is supported on both M1 and M2. So you can buy either of them.
Thanks
John
@GerardOz wrote:
@JohnPeng wrote:
@gavrook wrote:
Hi, my device is still on firmware NTGX24_10.13.05.00 with PRI Version 02.10Seems like you are using a Telstra MR2100. We have submit the new release to Telstra last week for approval. The upgrade will be posted in next couple of weeks if Telstra can finish the test on time.
Thanks
John
@JohnPeng
Hi John,I am about to buy an M2 off Telstra Australia, and will need to use Nertgear orbi or a Mesh wifi set up of some sort to extend the wifi range. All the forums are saying that the IP Passthrough is disabled in Telstra supplied M2's in the software. Mention is made of this changing in an upocoming firmware update, Is this true have they switched that function back on again ? It is impossible to contact Telstra technical due to Covid 19 now.
Or I can get an as new M1 secondhand and apparently I.P. Passthrough could be done on this model with telstra but then people reported on forums that they did one update and lost the function after that rendering the unit useless for their purpose. But that it was meant to be re-activated in a later update. The M1 will be fine for my requirements but I'm having a real hard time of finding out the facts on this.
Do you know about this?
Cheers.
Gerard.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@GerardOz wrote:@W1lliam Ohh ok so I get it now, whatever carrier you are on now with, its that carriers settings your getting from their Firmware which are different to Telstra here in Aus. So therefore you get the I.P. passthrough. The carrier your with must be selling the M2 also then, but you just have the Aus version. It must be unlocked too is it to work on that carrier?
OTA server should be still hosted by Telstra, even if the unit is with the SIM from other carrier. It might be caused by lock/unlock difference for this IP Passthrough function disabled.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, how do we get the device's json file?
I am also on firmware NTGX24_10.13.05.00 using a Telstra branded device. I am using a non-Telstra SIM Card and cannot get any further updates. Looks like this firmware was released in May 2019 - so it is quite old.
I can confirm that I have the IP Passthrough option but I am not using it at the moment as my new router doesnt seem to like the setting. It was working with my previous Airport Extreme router.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks.
is NTGX24_10.13.05.00 the most recent for the Telstra branded devices?
i know that the firmware updates are always at the mercy of the carriers vetting and approving them first.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is there any other option other than OTA? There is no 'upload' file/offline update section in the firmware updates of my device.
Telstra may never even release the fimware even though it seems like it has been flagged as critical by Netgear.
- Mark as New
- Bookmark
- Subscribe
- Permalink
hi William, can you please confirm you have inbound port forwarding working on your M2 with that firmware version?
Cheers, Jim.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@DrEvilJim wrote:hi William, can you please confirm you have inbound port forwarding working on your M2 with that firmware version?
Cheers, Jim.
With NTGX24_10.13.05.00 FW, AUS version does not have Port Forwarding function provided.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
unfortunately no. netgear will not fix this fault. the new M3 is coming out soon.
- Mark as New
- Bookmark
- Subscribe
- Permalink
so whats the latest firmware for this device? I have an unlocked UK EE unit on 10.13.09 - works ok but upload speeds dont compare to my old M1 unit. also are there new capabilities such as DDNS on latest firmware perhaps? mines dated May 2019....
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I'm in the UK on EE with the following:
Firmware: NTGX24_10.13.09.00
Firmware build date: 2019/05/17
PRI: 03.01
Modem: SDX_10.21.01.01
Can you confirm if this is the latest firmare for this device please? I'd be surprised if it is. Main reason I ask is that I get the reboot issue/bootloop issue on occasion (plugged into USB-C charger, no battery inserted). It's a little bit frustrating really and I want to get this resolved or the device needs to go back.
Thanks very much.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@smiff1985 wrote:Hi, I'm in the UK on EE with the following:
PRI: 03.01
Thanks very much.
@smiff1985 you'd better to check if your charger supports QC3.0, especially on its rated 5V current number.
- Mark as New
- Bookmark
- Subscribe
- Permalink
First, I often use the official charger and cable. I'm not checking anything further on that as it's Netgear's own.
I've tried it in various combinations with other chargers.
All my other chargers support either or both QC and USB-PD.
It's important to note that the official Netgear charger is a USB-A (wall plug end) to USB-C (M2 end). This charger only outputs at 2.0A at 5V, so the device doesn't require more than 10W. I use a USB-C to USB-C power point in my car which charges all my USB-C/lightning phones rapidly via USB-PD as I use an 18W output charger (Pixel 3 / iPhone XR / iPhone 11). So I doubt it's that either.
And judging from this forum I don't think I'm unique in the issues I'm facing. There's a whole thread on reboot issues with the M2. When it doesn't reboot, it works really damn well. My main issue is that it's really unreliable.
