× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Netgear Nighthawk M2 WiFi enable schedule
JimmyMars
Follower
I would like to enable the wireless schedule.
1. I went to the configuration page of my router: routerlogin.net
2. Logged in
3. Setting -> Security -> Schedule
4. Created a schedule: 5 a.m. to 9 p.m.
5. Clicked the enable tickbox and select apply from the bottom tab
The instructions here were outdated: https://kb.netgear.com/24102/How-do-I-set-up-the-wireless-schedule-on-my-Nighthawk-router#
But now after updating, it doesn't work as expected. The WiFi is not shutdown at 9 p.m..
I cannot find the option to change the timezone in this configuration page.
Shall I revert to an older firmware?
Current latest firmware version: NTGX24_10.17.08.00
Model: MR2100|Mobiler Router Nighthawk M2
Message 1 of 2
Accepted Solutions
Blanca_O
NETGEAR Moderator
Re: Netgear Nighthawk M2 WiFi enable schedule
Hi JimmyMars,
Welcome to NETGEAR Community!
Have you tried factory resetting the device?
The KB article that you posted is not applicable for Mobile routers.
For Nighthawk Mobile router, you can setup a schedule for Internet access. Here's a reference:
https://www.downloads.netgear.com/files/GDC/MR2100/MR2100_UM_EN.pdf [page 48]
Blanca
Community Team
Message 2 of 2
All Replies
Blanca_O
NETGEAR Moderator
Hi JimmyMars,
Blanca
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1736 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
