- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NightHawk MR1100 Telstra to Netgear Stock EU
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
does anyone know, if it is possible to flash an Netgear EU firmware over an Telstra Firmware?
I own an telstra device and stuck at firmware 10.16.04.04. I read that there is already a newr version also from telstra, but in here in Austria with "Drei", i don't get an update. It just says, its up to date. 😞
Would be great if can be changed to an EU Firmware Version.
thanks
br
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi diehummel,
If you refer to the link below, It is instructions to manually update your Telstra M1 device.
Please let me know if this works for you. :]
https://kb.netgear.com/000055962/Why-can-t-I-see-data-usage-on-my-Telstra-Nighthawk-M1
- Jason N
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NightHawk MR1100 Telstra to Netgear Stock EU
Hi, the OTA server is buged for worldwild.
I don't if it is possible to flash TELSTRA firmware to a EU firmware but if it is possible , i would like to know how to do, it is interesting.
You are a locky guy i'm still in 10.12 version very very very old.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi diehummel,
- Jason N
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks!
But 2 days ago, i got the update also with the update button.
However, the new version works much better now 🙂
br
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi diehummel,
That's great! I'm glad that you were able to update the firmware and that it works for you! :]
Thank you for letting us know!
- Jason N
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
the 10.25.01.01 seems still a litte buggy.
The Ethernet Port ist set to Standby disabled, but when i restart my PC, i have to push the button the the M1 to get Ethernet working again.
The PC has a Static Private IP.
I have now changed the Standby Setting again to 2 Minutes and reverted to disabled to check if its working now.
The M1 crashed 2 days ago. Maybe he lost this setting during the crash and used the 2 Minutes as default afterwards.
br
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
i found, that the cause that the ethernet stoppped working, was, when my pc crashed.
i have an mining tool running, and the tool caused a crash of my pc. Everytime the PC crashed, the M1 stopped working on the ethernet port.
But the PC is not connected directly to the M1. Its connected to a GB Switch, then to an TP-Link Router, and then the M1.
When i shutdown/reboot the PC normal, the problem does not occur.
