- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk LTE mobile router stand by power usage
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all,
I want to install an LTE mobile spot serving an IP security cam on a boat where I have no access to shore power save for installing more solar cells. I need to calculate a power budget. I like the nighthawk hotspot since it has ethernet port so can plug the camera directly and save on wifi power. Usage will be very occasionally checking on the boat (so few secs/minutes video/shots uploads per week)) or as needed (alarms). Hotspot will basically stay 99.9+% of the time in stand by. What would be the expected power drain of the hotspot itself ? How long the 5000mA battery would last ? the spec'ed 24 hours life is with a quite heavy 66% downloading activity I understand. If I leave it plugged what would be the drain/loss in mA from the USB charger to keep the battery charged ?
Thanks
Alex
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk LTE mobile router stand by power usage
Hi Alexp69,
Can you please provide the exact model of the unit?
Blanca
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't think the Netgear nighthawk would provide good solution for your cam recording and heavy download requirement. Better to try other netgear WiFi routers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The model is the MR1100|Nighthawk LTE Mobile Hotspot Router, the ATT offered one. I just read standby time is only 1.7 days and use time is 24hours on their spec page. Which seems weird.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My usage is going to be indeed very light indeed...few minutes day/week...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Alexp69,
You should assume that the AC to DC charger is the main consumer of power. I'd recommend you buy a good QC2 or QC3 charger (from Anker for example). Like this one:
https://www.anker.com/products/variant/powerport-speed-2-ports/A2025111
Power consumption will vary between 0.5W and ~20W if only a single device is plugged in.
