- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk LTE on AT&T
- Mark as New
- Bookmark
- Subscribe
- Permalink
New here, well very new just found this place. I use my Nighthwak for home internet and have a couple burning questions and cannnot find someone at AT&T knowledgable to ask.
1. Does the Ethernet port work on AT&T to feed a switch and then have it feed a wireless access point? Anything special one would need to know?
2. External Antennas I have 0 clue trying to figure out what I need and how much better signal strength (currently 2 bars) will give me. I logged into the desktop view of the router and tried to ask AT&T about some of the values I saw there and they had no clue what anything meant.
HELP!!!!!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk LTE on AT&T
1) Yes, you can do that, but suggest turn off the WiFi in the Nighthawk itself.
2) I live in a remote area and I get nothing on my Nighthawk M1 without an external antenna. I have tried two: 1) The Proxicast 4G/LTE cross polarized panel antenna and later 2) a pair of Proxicast 9/11 dBi Ultra broadband antennas arranged in a cross polarized mounting.
I mounted them on a 10' mast from the high point on my house and ran 15' Low loss 50 ohm coax extension cables with SMA female to TS-9 pigtails to connect to the Nighthawk. Where I am, no perceptable improvement in performance from case 1 to case 2.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
AT&T Mobility Prepaid for 6 months, then I'll get it unlocked and try SIMs for Verizon and T-Mobile to see if either of them work.
My objective with this was not for everyday use, but for emergency outages of my Xfinity cable HSI service. With two recent storms this past winter, power, cable, Internet out for a week at a time so we were cut off from all communications.
I am getting about 8 Mbps D/L and 1-1.5 Mbps U/L. The AT&T tower I am connected to is 8.2 km southeast of me at bearing 147 degrees on AT&T LTE Band 12 (700 Mhz). I determined this my looking up the tuple of { MCC, MNC, LAC, CID } as reported on the Network > Advanced Info page on the website OpenCellID.org to find the LAT/LONG of the tower. You can use Google Maps or the service on Mobilefish.com to calculate the bearing and distance from your own location. FInally, I used the compass app on my iPhone to align the antenna direction to that true bearing.
I decided on this method of alignment because trying various other bearings and trying to guess what was best was not getting it done. The antennas are not all that directional that you can detect a null given the variation in signal level over time anyway. I suspect if your cell tower is considerably closer, then antenna direction will be more of a factor. During my testing, I noticed that the Cell ID number never changed. That is regardless of the direction I pointed the antenna I never connected fto a different cell ID even ones I knew to be much closer BUT my location is in a RF "shadow" of the surrounding terrain.
I went to the trouble of mapping nearly 3 dozen cell towers within 8-10 km of my location and generally to the southeast and built an Excel spreadsheet with bearings, distance, and carrier to make any Verizon/T Mobile testing go quicker as far as antenna alignment goes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I get 1-2 bars now with the external antennas. You should look at RSRP (and the two below it in the table) and Quality on the Settings > Network > Advanced Info page of the Netgear Mobile app.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Northwest NJ. I just have a thing for the metric system I guess.
- Mark as New
- Bookmark
- Subscribe
- Permalink
There was a third antenna which I tried early on: Wilson Electronics 12 inch dual band mobile antenna w/ SMA Male connector (vendor claims it works on 700 MHz bands as well). You will need one of the SMA female to TS-9 pigtails to connect to the M1.
This antenna needs a ground plane and is intended for magnetic mounting on the roof of a vehicle. So, park your vehicle so that it is not in the RF shadow of the antenna created by your house and try the Nighthawk M1 with that. I cobbled together an 8" square ground plane and stuck it on top of a piece of 1" Schedule 40 PVC pipe and carried that around my property and up on the roof for initial testing, making multiple measurements at each location. Perhaps that will be good enough for you since the cell is ~ 5 klicks away. Much cheaper than the Proxicast 4G LTE panel with cables and you might use it mobile some day anyway.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My RSRP stays right around -100 now as in right now I have 3 bars but its usually at 1 or 2 coincidentally it is a bit faster right now. WHat other measurements mean anything? I'm kind of stunned I called tech support and spoke to 3 different people and no one could tell me what any of the info means...
- Mark as New
- Bookmark
- Subscribe
- Permalink
My best ever observed RSRP is -110, so -100 is significantly better. If I find the web page, I’ll post a link.
With outside antenna gain of 9/11 dBi, and assuming no other losses, you might approach -90 dBm.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have seen this suggestion early on in other posts, but it was never clear to me why turning off the M1 Nighthawk's WIFI is suggested when plugging it's ethernet port into a another WIFI router's WAN/Internet (input) port. Can you explain the reasoning?
The way I have tried hooking this up on my end, my M1 Nighthawk's WIFI IP range is 192.168.2.20 - 192.168.2.99 and the WIFI router it is connected to has a WIFI IP range of 192.168.0.20 - 192.168.0.99. Based on this, there is no WIFI IP conflict. It is unclear why else we should consider turning off the M1 Nighthawk's WIFI.
- Mark as New
- Bookmark
- Subscribe
- Permalink
In my mind, when you connect the Nighthawk M1 by its ethernet port to the WAN of another WiFi router, you are using the M1 as your Internet source (exactly like a DSL or Cable modem) and then connecting your devices to the WiFi router which creates your LAN, with some clients perhaps hard wired to ethernet ports and others via WiFi.
If you leave the WiFi on the Nighthawk M1 enabled, even using the SSID (wifi network name) as your existing WiFi router, then devices connecting to the M1 will be on a different network (192.168.2.0) than devices connected to your second WiFi router (192.168.0.0) and will not have access to any network resources on your second (existing) LAN (192.168.0.0). If there are no such resources that you care about, then leave the M1's WiFi enabled and it will provide you with just Internet access.
Regardless, your second WiFi router will also complain about double NAT unless you configure it to ignore double NAT.
