× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Nighthawk M1 Gateway IP Change
derbast
Hi, i need to change the Gateway IP to 172.16.1.1 , but i cant.
Invalid IP Adress, Please use an IP adress within DHCP range.
But DHCP is Turned Off, wat can i do now ?
Firmware is the newest
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 2
Accepted Solutions
derbast
Re: Nighthawk M1 Gateway IP Change
i found it out, you need to change the dhcp settings before deactivate DHCP
Message 2 of 2
All Replies
derbast
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2068 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
