× Some paid Circle Parental controls customers may be showing free options only. Router firmware correcting this issue will be available ASAP. Visit Status.NETGEAR.com for updates.
Discussion stats
  • 2 replies
  • 697 views
  • 0 kudos
  • 1 in conversation
Announcements
Top Contributors
Reply
Highlighted
Guide
Nighthawk M1 - Set WiFi ac only
I'd like to set the wireless mode for the 5 GHz radio to "ac only". This is possible on most routers, even mobile like this one.
"Modes" are references on the status page in the web portal (see image) so I find it strange that there is are no settings for changing it. This would also apply to the 2.4 GHz radio, being able to set it to "g only".
Or, is it possible do to that with the latest firmware, 12.06.03?
Best regards,
Mikael Dúi Bolinder
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 3
Accepted Solutions
Highlighted
Guide
Re: Nighthawk M1 - Set WiFi ac only
One can also change this by exporting the settings, editing the value and then importing them.
Best regards,
Mikael Dúi Bolinder
Message 3 of 3
All Replies
Highlighted
Guide
It's just a GUI question. You can use the API (took me a few minutes to set everything up) to change the modes to M802_11_GN and M802_11_AC.
Best regards,
Mikael Dúi Bolinder
Message 2 of 3
Highlighted
Guide
Best regards,
Mikael Dúi Bolinder
Message 3 of 3
