× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Nighthawk M1 mobile router not showing data usage
Nightwho
When will netgear release a new firmware update for Telstra Netgear Nighthawk M1 Mobile Router ?
 I updated to the latest firmware NTG9x50C_12.06.02.00 which caused my device to not display data usage & keeps displaying “Detecting Service”.
Message 1 of 7
Accepted Solutions
Blanca_O
NETGEAR Moderator
Re: Nighthawk M1 mobile router not showing data usage
Hi @Nightwho
Please be informed that firmware upgrade has been released for MR1100 Telstra Variant. This is to address the data usage issue not available. Kindly check your device for new firmware update and provide feedback.
Firmware version is 12.06.08.00
Blanca
Community Team
Message 5 of 7
All Replies
You might get better and quicker replies, and find other answers, over in the appropriate section for your device:
Mobile Routers, Hotspots & Modems
Message 2 of 7
Nightwho
Thanks GURU.
Have copied over to Hotspot.Smiley Happy
Message 3 of 7
JohnPeng
NETGEAR Expert
Fix for the issue will come soon.
Thanks
Model: MR1100|Nighthawk M1 Mobile Router
Message 4 of 7
Blanca_O
NETGEAR Moderator
Hi @Nightwho
Blanca
Community Team
Message 5 of 7
Nightwho
Thanks for the update . Yes, the new firmware works.
Message 6 of 7
Nightwho
Nighthawk M1 Firmware Version 12.06.08.00 is not coming up in updates.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 3841 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
